Okey Guys, ive posted a lot in the cafehusky forum, but in some way i like this forum better. ( Still have The Ec 300 standing in the garage looking gooood)
The bike is a Husqvarna TE 250 , 2010 with 130 hour on it .
When i was driving two weeks ago i came to a bend, running not so fast at all, 1/2 throttle 2 gear maby, then suddently the engine totaly lockt up on me, had to walk the bike back. I had a quick look at the starter assy in the garage and it all seemed to be ok, So i ript the head and cylinder of but everything was alright there too, also had the clutch plates out. It was the starter gear that had split and lockt the engine.
Yesterday i assembled the bike again and it started fine. BUT i have clutch drag from hell! When i have the bike standing in Neutral and im holding it, it drives away from me, not fast but it runs away.
Then problem nr 2, the drive shaft is heavy too turn, you even feel it when u walk with the bike turned of.
My heart says that this is oil related and should maby go away after i run for real for a while, i went out for an 5 minutes ride yesterday, maby it wasnt enough for the oil to get everywhere . I run specified oil, 10-50w fully synthetic
I have a little bit of a dilemma, The problem could go away if i drive, or this problem was the caus that killed my starter assy, and will kill it again forcing me to pay another 350 euros in parts.
What do you think, should i drive with it, or should i let it stand in the garage for a couple of years?? Maby picking up table tennis instead??
I?m all lost in this, I refuse to tear it down again :-/
