mountain thumper
so my new to me ltr powoevalve and case saver came today thanks jim, very nice parts, fit great!
i put on the pv cover easy enough, was even able to reuse gasket..
that i started on the case saver.
(obviously) clutch fluid everywhere, expected that. so i get everything back together, had clutch still, but i was going to bleed it anyway, so i followed the manual bleed directions, squeez lever, release valve, tigten valve, release lever till no bubbles. problewm is, im an idiot so i loosened the whole bolt, not just the petcock. so i realized this mistake and started over. i did it for 2 hours, i even took off the lever, to be sure of full stroke. but, no clucth, at all.
tried pumping before releasing pressure, all with no effect.
so i went and got a"flavor injector" and put a tube on it to force it through. wouldng go, just built up pressure till the hose came off, and sprayed insanely slippery LAXATIVE (thats the only non petroleum mineral oil i could find) all over myself and the bike= not being able to hold on to tools or parts.
so i bought a nice mighty vac pump to suck fluid thru, like on auto brakes, and it would just build up pressure till the hose collapsed.
imo its obvious i have a blockage., i dont know how, im very careful about contaminating reservoirs.
so how to i purge my line (i cant afford a new one right now)
and another question is how much should squirt out when lever is pulled. the first one was massive, but all after that barely had enuf to make it out of the petcock.
im pulling my hair out, which in itself is causing more problems cuz i shave my head
i would love you forever if you could help me!
