pscook
Okay, I've been fighting (tolerating?) an engine which runs terribly for the last year or two. Yeah, I don't get to ride often enough. But here's what I have gone through as well as the troubleshooting history:
Troubleshooting:
What I'm doing now:
What else am I missing? I will get some solder and run a squish test, but I'm pretty sure it's excessive, and I don't think the excessive squish would cause it to run poorly. Plus, it ran fine before I got my hands into the engine, so it's something that I did to cause the issue. And it's always had a freshly cleaned and oiled air filter, no rags in the intake.
Lastly, here's a stupid question - With a Wossner piston, the arrow points to the exhaust, right?
Upon reflection, it's really starting to lean towards the silencer.
Thoughts?
- New piston
- New pipe o-rings
- Lectron 38mm carb
- Replaced Q Stealth silencer with Leo Vince
Troubleshooting:
- Reinstalled stock 36mm carb
- Checked Power valve (it works, verified with cover off and running)
- Reeds good (very little wear, no daylight)
- Swapped CDI like for like
- Verified no rags in the intake or exhaust
- Timing is still where it should be, no broken or dislocated parts on the stator plate
- New plug(s), tried two different heat ranges and E, EI, EIX, whatever, no difference
What I'm doing now:
- Pulled jug, piston looks good. No wear marks, no scoring, no evidence of seizure or other shenanigans. Carbon on the top, but not excessive (to me)
- Going to swap Leo Vince silencer back to the Q Stealth, just remove a variable (ran fine before, might be the silencer)
- Check all grounds
- Replace ignition coil (you never know)
Thoughts?
