Terrence R
Just took my top end off to put in a thicker base gasket. I ordered a new set of rings for the wossner piston I have in it and a top end gasket kit. I only put 20 hrs on it since I rebuilt it last. I use motul 800 and I'm more than very pleased with how everything looks inside. The piston looks the exact same as when I put it in. All the black coating is still there and the crown is so clean. Everything came apart very well lubed. The dome of the head has a nice moist looking gold film from clean burning carbon.
So, I took a circlip off to check the piston for any cracks and to check the upper part of the rod, etc. I bent the circlip badly on removal and need to replace it. I know that it should be replace regardless as they aren't re usable. Is there any sort of crossover for these circlips?
