In search of that little bit of rubber intake hose that goes from the carb to engine. Anyone know if I can get the same piece of a more redily availible manufacture?
Another member on here went to the auto parts store and got a piece of fuel neck filler hose and just cut to length, hose clamped on. Cheap quick fix that he just left that way since it worked
The correct part has ribs the lock into the carb inlet and reed cage notches to lock it in an prevent it from slipping out. If you buy them from Boyesen the are only 10 the 15 bucks.
