Gday guys. Ok I have an 07 EC300 which I took out the other day and found an issue with my jetting. Currently I'm running the following setup:
#7 slide
178 main
48 pilot
LTR kit needle on the 3rd clip
The temp would have been in the high 80s to mid 90s. This I think would be the hottest i have ridden in with the Gasser. Anyway. From 3/4 throttle to wide open it seemed almost like it was missing. The rest of the throttle revved clean. After pulling the plug it was a touch white with no fouling or wet look at all. My thinking is that I need to go up to a 180 main and after that maybe down to the 4th clip from the top on the needle (if the main jet doesnt fix it completely.) Does this sound about right ???
Thanks in advance guys.
Ben.
#7 slide
178 main
48 pilot
Ben.
