The piston, clutch basket and clutch plates should be the same as a late 90's Honda CR125. The front sprocket should be the same as a 1997-2002 Yamaha YZ125. The top end gasket set should be the same as a 97-01 YZ125. You need to make sure that the powervalve isn't locked in the closed position - you can look and see if there is a countersunk hex head bolt on the powervalve cover. If that bolt is there you want to make sure that it offset towards the top of the cylinder.
I geared mine 13/50 to get it out of first gear, shortened the silencer to help with the bottom end power as well. The only issue I've had with my 2011 is that it seems to eat pipe o-rings, clutch plates and silencer packing. It's a fun bike to ride and is excellent for teaching a rider to carry momentum thru the woods.
