mtnmanseth
I'm not sure if this is a common problem with this product, but while pulling the motor to do a bottom end job because a terrible metal-on-metal sound made me think a major bearing was exploding, I found that it was actually the flywheel weight had somehow spun itself off the mounting bolt. Can't tell if it was originally welded, pressed, or machined as one piece. Regardless, the sound this little bastard makes while spinning on the outside of your crankshaft will make you think you bike is about ready to melt down. If you have 2005ish bike, keep an eye on any cracks or fatigue on this piece...
Now I need to decide whether to just install the new flywheel weight from Checkpoint Offroad and ride it, or continue with the teardown and do the bottom end while I have it half way apart and all the parts in my hands. We'll see...
