Kickstart not retracting after kicking???
wence
Bronze Level Site Supporter
As per the above.
This is the second time it has been apart and both times the kickstart is really tight.
The spring has been checked and double checked and is the end of the spring is located in the hole correctly.
Anyone had a similar problem?
It is not a real drama but would be nice to not have to lift it up with my foot after starting...
Cheers Mark
I did check other posts and found one where I think it was widebear was saying there is a plastic washer or something.Also has anyone got pictures of how I can adjust tension or spring position?
Thanks again Mark
Check the plastic bushing that resides in between the shaft and the spring and make sure that the relief slot in the bushing is properly indexed on the spring.
THE DUDE ABIDES
widebear
View Public Profile
Send a private message to widebear
Send email to widebear
Find all posts by widebear
Add widebear to Your Buddy List
#3 07-05-2009, 05:46 AM
GasGasDreamer
Member Join Date: Apr 2009
gasser250sm,
I am no expert, but there are two springs.
The one that is 'weak' and pushes the gear up, and then there is the spring that provides the tension, or the force that brings the kickstarter back to the 'rest' position.
I believe that this spring can be installed in multiple positions. Too much one way provides to weak of a return, too much the other way provides for a extremely strong return.
I don't know if you can tell it's right or wrong until you install the kickstarter and give it a try.
I put my kickstarter on before I put he case side on just to test it.
I think I installed it a little too strong, but the enemy of good is perfect.
Just my info. Hope it helps.
GasGasDreamer
