Kickstarter
gasman88
My kick starter on my 2005 ec250 is toast. I tried stretching the spring and making sure everything is tight. It's just worn out. Are there any other Kickstarter that you guys run from different bikes that are easier and cheaper to find? Yz250 or any other 250? Mind won't stay closed and it's annoying. And rattles against the pipe which is annoying too. Thanks a lot guys. -Josh.
Yeah I run a yz250 kicker on my 07. Got the crossover info from here so search and you will find.
I've tried the search option many times. It doesn't work on my phone. I don't really have access to a computer. Is it bolt on?
Any yz or older yzf250 kicker will work. Not sure if the current generation yzf still works or not
kickstarter
Check the crossover parts list. The years and part number are given.
Here you go yamaha yz part number 5nx-15620-00
kick starter
Always glad to help. You are getting a good deal on that new kicker.
The yamaha brand is around $100. I will need one myself soon enough,
Trailrider
Yeah it arrived a couple days ago. Didn't put it on yet but the build quality seems really nice. It's heavy duty and doesn't feel cheap. I think I scored on that one. Considering they want almost $100 for a used gasgas one. And it's also longer for more leverage. It was a good buy. Thanks for pointing me in the right direction man. Much appreciated. -Josh
In the search window,if i try typing in box on my phone the window disapears.but if you hit search,when the window opens dont type anything,just hit "go" it gets you through to the next search step
