Kx 85 problems
Hi guys I know it's not a gasser but thought u might be able to help .. my mates Bought a kx 85 that has a few problems .. first problem is when u kick it into gear unless your revving the tits off it it'll die .. and the second problem is any sort of small hill it'll bog down an die , but on the flat it rips tidy .. had the carb cleaned which helped a bit .. the bike starts up easy enough and will idle for as long as u want it too ..
Well I'm getting a KX85 in my shop tomorrow that belongs to one of my sons friends'. It has the same problem. I'll let you know what I come up with
Usually a bog is caused by a lean condition so make sure you can see through the pilot jet. Also check the intake manifold for cracks/leaks.
pull the clutch cover off, pull the plates off and check for wear marks in the inner hub and basket, if theres grooves in them itll make the plates stick........
