fullthrottle New member Dec 7, 2008 #1 hi i have found that every couple hrs i am loosing about 50-100ml of water were is it going??
wence Bronze Level Site Supporter Dec 7, 2008 #2 probably got a leaking head gasket. Water leaks into barrel and is evaporated as steam. Happened to my Rmx 250
H Hamish New member Dec 7, 2008 #3 I had a small crack in a radiator fin, would only leak under significant pressure. Also had a shot water pump, that would cause overheating and therfore water loss Check to see if your has the plastic impeller...if so my advise is get rid of it
