fullthrottle
My bike has never had an idle issue but went for a ride yesterday and was running well after about half an hour went to let idle... stalls
wont idle no mater if idle screw is spring bound (my idle screw is usuall pretty far off spring bound) and choke seems to not make much diffence
Straight away think blocked pilot as have just had carby apart cleaning checking float heights etc so mabye a bit of dirt was left.
Anyway when I get home pull float bowl remove pilot would say its partially blocked clean out reinstall was late so waited till morning to start it.
This morning start bike seems the same choke still has minimal effect so pull choke plunger out seems normal blow some compressed air down chocke hole refit choke idle is back have to wind idle screw back out a few turns and reset a/s to 2 turn where is was before thankfuly.
any one had similar issue?
