D Des147 New member May 17, 2020 #1 Is it possible to change a 2010 ec250 lower rocker arm linkage and fit a 2012 or newer rocket arm. So it will take a newer shock
gasgasman Super Moderator Staff member May 17, 2020 #2 No. Where it mounts to the frame is different. The 2011 Nambotin model did have the 2012 lower rocker arm.
gasgasman Super Moderator Staff member May 17, 2020 #5 I don't know of any. I guess you can modify your frame to accept the new link. You can't get your current shock to work for you?
