This is for my 2011 EC300.
A late model KTM 2T 9.5mm will work, correct?
Plug and play (same thread pitch?) , or do I need to get a new line made?
Thanks in advance.
All late model ktm's are Brembo I believe.
9.5mm Magura works, at least older model. I do not think that there is any change in clutch line thread. Please note that You need master cylinder to work with mineral hydraulic fluid so Brembos which are meant to work with DOT4/DOT5.1 are not compatible.This is for my 2011 EC300.
Thanks in advance.
I could be wrong, but I believe the 4 stroke ktms are Brembo too.
I recently rebuilt my Magura 9.5 on my 2012. I was under the impression that just the 2012 GG were Magura and they switched back to AJP for 2013??? Call GoFasters, he knows. He told me the deal but I can't remember exactly.
MargusV said:9.5mm Magura works, at least older model. I do not think that there is any change in clutch line thread. Please note that You need master cylinder to work with mineral hydraulic fluid so Brembos which are meant to work with DOT4/DOT5.1 are not compatible.
In my personal opinion Magura is not an upgrade over the stock AJP which is actually a very nice unit. A bit less bling than Magura but thats not relevant to me.
Actually mine used to leak, too, but as it was on 2 years old bike which was well used (and somewhat abused ) I just swapped in the rebuild kit - cheap job, 5 minutes and done. No problems since then.I don't know, my AJP leaked from day one. I am tired of fussing with it.
I bought the new style Magura, looks to be a bit more compact than the old style.
