Main bearings kit
swehollow
Hi. Does anyone know if the Main bearings on my GG 250- 03 is used on any other bike? I cant find Gasgas specific parts here.
contact north tahoe motorsports....they put together a whole bottom end refresh kit for my 07. The owner still rides an early 2000's gasser and would probably know. I've bought a lot of parts from him because he is so helpful (and I don't have a local parts place)
Bob Piper at North Tahoe is a great resource. I highly recommend him for technical ability as well as his parts availability.
His email is ntms1@sbcglobal.net
He is alos on eBay at http://www.ebay.com/usr/n.tahoemotorsports?_trksid=p2047675.l2559
The bearings are common and are used in many other European and Japanese bikes. The did change them from year to year but they are readily available once you know which ones you need. Check out AllBalls which may help you cross reference. I think your bike will need the roller bearing on the ignition side NJ206 ET -C3 (LHS) and a ball bearing 63/28-c3 (RHS) on the clutch side. All Balls has the kit for $103 including seals, but I would call them to find out what flavor bearings they are using. Try to stay with a quality name brand from Japan.
