My '00 will flat eat my kids '04 alive. Differences are 2K2 ignition (smaller flywheel), gnarly exhaust, no reed block spacer and my XC uses the '00 era 200cc CDI which has a different timing curve. Not sure how that would work with your 2-position map switch assuming you have one. Huge difference. That was before the RB squish modification and LTR power valve cover. Same gearing, 13/49 I think. Like an XR vs a CR.
