mcnut
I need one bad. GasGas p/n BE250514247, the "compression piston". Mine was damaged trying to remove it from the damping tube after the bottom stack came apart. Apparently when I tightened the bottom valve with an air impact (because I don't have the special tool required to hold the top), it spun the compression stack loose. Piston got lodged in there sideways. Shims were damaged also.
Currently the fork is at Enduro Engineering for re-valving but they can't find a piston. GoFasters doesn't have one. Marzocchi USA doesn't either. Got to get this thing going real soon! Help!
