d2w
My 2006 EC300 came with two pipes; a silver one and a black one (which, looking at the additional plumbing, may be a catatytic pipe). Has anyone attempted to convert the catalytic pipe into a standard pipe? Do you think it's possible to open the pipe, remove the catalytic element(s), seal the plumbing holes, and reweld the body? And, once that's done, would the performance be equivalent? The two pipes look similar in size and shape.
I guess there's no harm in trying (as the black pipe is just collecting dust in my crawl space!)
OK, I did a little bit of visual inspection and probing (with some flexible tubing); the only extra hole/plumbing is near the exhaust flange, and I'm sure it could be quickly cut off and welded closed. And there does seem to be some sort of obstruction near where the pipe begins to expand (after the upturned "U"). The obstruction is positioned near a weld, and feels "thin" like a plate. Perhaps it's a plate of the reactive material? At this time I can't see why I couldn't build a jig so as to preserve the alignment of the pipe, and then cut the pipe at the suspected plate and attempt to remove it. I'd then weld it back up using the jig. Heck, I can even use the jig to realign any future pipe damage.
Dale
Dale
