Mousse blow out
Cox76y
Just wondering if anyone has had a mousse fail on them. I was on my 3rd ride with a mousse over the weekend when the mousse tore in half and fell out of the tyre. I was very surprised as I thought I would get a lot more use out of it.
No nothing like that with mouses.
The only problem I have had is with a mouse that had shrunk on the front and the front end would fall away on certain corners.
The mouse was well used and old.
was your third ride close to your first or long periods between rides? I know mousses need to be lubed regularly (every 6 month or so) and also don't like high speeds (remember the first dakar in South america?)
The bike should also be stored on a stand so the mousse doesn't develop a flat spot
all reasons to use tubliss ;-)
Probably about 5 months since I got it installed. The bike had been up on a stand for some of that time. Think I'll go back to tubeliss now. Pity about my golden tyre. I might try to throw a tube in it..
Nitro Mousse are junk.
I found out that you pretty much have to run bibs mousses in Michelin tires.
What brand? I have had bad luck with the Nitromousse brand.
I think there was an issue with the first gen of nitro mousse with them shrinking, not sure if there was a recall, but have heard there is a new version
I know tubliss says to use a new tyre, but if your old tyre is still in good condition i would try it anyway, maybe add a bottle of slime in with it to seal any deformities from the rim lock
Not sure what brand of mousse it was and I don't know if I'll get a good seal from the tyre now. We were able to get the tyre back over the rim without using levers. I'll have a better look when I get a chance.
If you were able to get the tyre back on the rim without levers, whoever installed it has broken the bead and that?s what caused the mousse to come out the side.
Seen it before a fair few times.
quite possibly, there is the right way to install a tyre with a mousse and a wrong way. The guys at six days enduro do it in about a minute and make it look easy
The hard way involves brute force and broken tyre levers and beads
just wondering does anyone run TUBliss gen2? What are your experiences, are mouses better? If so, what brand?
It all depends on what you want. I don't run Tubliss, but the Swedish competitor T-Lock.
Mousse is better in some things, the Tubliss / T-Lock is better at other.
The feeling / advatages of having really light wheels (less unsprung and rotating mass) is the main reason why I run T-Lock instead of mousse.
I have run tubliss for many years, started with gen 1 in 2006 and eventually ended up gen2 - effectively the same, but gen2 refines some of the gen1 issues - if i remember it is things like rounder rimlock to prevent cutting through the tyre and thicker inner tube (i had my gen1 tube explode for no reason) but basically the same.
The benefit over a mousse is basically being able to change your tyre pressure as you want, whereas a mousse starts hard and ends its life soft so is only the correct pressure at a point in its life.
Mousse is puncture proof (provided it is installed correctly;-)) but tubliss can be plugged 95% of the time and provided the inner tube is in tact you can ride a flat tyre with almost no damage to the rim (i did about 50km of pretty extreme rocky riding at about 70% pace) on a sliced tyre and just replaced the tyre in the pits and rode the next day, the tubliss works like a full rimlock and also the inner works as a bit of a bumper about 20mm proud of the rim so even after the 50km the tyre was still in pretty good shape
in short, unless you are racing for a win i would rather go tubliss
(also it is also the easiest system when it comes to changing tyres - provided you follow the tubliss rules)
I've run Gen 1 and Gen 2 Tubliss for over a decade now. I've also run Michelin bib mousse's.
If you like a more dead feel, and absolute zero chance of failure during a race if everything was done right, a mousse might be for you. If my last name was Jarvis or Lettenbichler then it would be the only thing I would run when money is on the line. That said, I hated them. They're a PITA to install and maintain, I hate the dead feel, and they are more costly vs Tubliss or UHD tubes.
I'll admit, I'm a Tubliss fan boy. I love being able to adjust air pressure to find what works best for any compatible tire, easier tire changes (even though some seem to not be able to do it :confused:), lasts way longer than a mousse, and I can finish a ride/race even on a flat tire as long as it isn't a super soft sidewall type, and fixing a flat requires nothing more than a tire plug. I've had this setup now on four bikes, two KDX's and two Gassers, and don't see myself changing anytime in the future.
