GasGas 300. First of all, GasGas uses its 299cc, liquid-cooled, power-valved, reed induction two-stroke engine off its popular 300 XC enduro bike. This engine puts out a claimed 49.4 hp at 7,340 rpm.
The engine uses a square bore and stroke configuration (72x72mm) for maximum horsepower output. Although the engine does not come equipped with a counterbalancer, it does have an extra weight added to the clutch side of the flywheel to help keep the engine from experiencing any vibration problems. The Gas Gas also comes with its own hydraulic clutch, which makes the clutch action exceedingly easy on the hands.
A Kokusan digital ignition supplies the spark while a 38mm PWK Keihin carb with a twist grip throttle gets the pre-mix to the cylinder. The power valve on the 300 engine provides maximum low and high rpm power by enabling the port timing to change with the engine rpm.
Housing all this trickery is a frame design that features a detachable rear sub-assembly and a detachable front engine mount. The front detachable frame member allows for easy access to the engine for maintenance, while the rear assembly will allow you to replace the rear subframe rather than have to buy a completely new frame.
The frame itself seems to be based on what the factory?s engineers determined to be the best geometry between a FourTrax 250R, a Laeger, and a Roll chassis. We took out our measuring tapes and recorded a front-end width of 47 inches, a wheelbase of 52, seat height of 32-1/2, and overall length of 77-1/2, with an overall height of 43-1/2 inches.
Sandtech Racing, rider Russ Ramsey riding the 300 GasGas. They are 3rd in points in the expert class. These guys are racing in the Nevada desert and their shortest race has been 260 miles long. They have 1 dnf because Russ got lost then ran out of gas. They finished second in the expert class in a 560-mile race from Reno to Las Vegas on June 27th. That tells you these quads are tough and can go the distance.
http://www.powersportsnetwork.com/enthusiasts/new_vehicle_detail.asp?VehicleCode=9078&st=HI
 The GasGas 300 is kicking some but in the Nevada Desert in the XC races. Sandtech Racing, rider Russ Ramsey riding the 300 GasGas is 3rd in points in the expert class. These guys are racing in the Nevada desert and their shortest race has been 260 miles long. They have 1 dnf because Russ got lost then ran out of gas last week. Their next race is June 27th and it is a 560 mile race from Vegas to Reno.
The guy said the bikes were holding up great.
They have had NO mechanical problems after 1700 race miles so far. The only mods they have done is tune the suspension and port it.
http://atvsource.com/forums/viewtopic.php?f=17&t=12796
