Need help on 99 EC200
H0TR0Dn
I dont think the spacer I have is right. I bought this bike and after a finding the previous owner drilled the top triple clamp uneven I am wondering about other stuff that doesnt seem right.
I took several pics. I got a new front end from Rick and it is a little different.
He wasnt sure if his spacer was the right one. Here is what I have
The spacer I thought should set into the fork tube. The left side of the red line fits in there but comes out when the axleis pushed in tight and nut is snug. You can see above the black line the axle comes out the end of the fork tube into the space where I think the spacer should be.
in the above pic is the spacer from Rick. It fits like I think it should but is a little too wide where the one on the bike I think is too small.
With Rick's spacer the wheel looks like it sits to the right of center. With the forks just hanging loose installing Ricks spacer I have to spread the forks apart an 1/8 in.
Or did I have the wrong spacer on that side. It looks like maybe it shouldnt go into the fork. Im trying this one now.
This is how mine came when I bought it. I noticed (just now) that the axle the side with the puller does not have a spacer. Hope this helps and gives you a better idea of what you might need or do? Let me know if you have any other questions.
Thanks, but your 250 must be different then my 200. I have to use a spacer. After talking to Rick and Jay, we think it is right. This is how I'm running it now
Hotrodn,, looks like you have a ktm axle,, the spacers are the same for my 97 250 and that is what should be on yours.. the ktm had a different right fork leg and speedo drive on their wheels. their axles(also Husky w/same forks) are very close but fit just a bit different.
Did it come with a KTM axle? The Axle and spacers I have came off Ricks bike and he bought his 99 ec200 new. My axle is the same but I had 1 different spacer which wasnt fitting right.
I'll take a picture of my axle tonight along with the spacers. The other pictured looks right,, I have several axles,,, from a Ktm, husky and my gg I'll make a comparison of them all. But the way the pull is doesn't look like the GG axle. Are you sure it's still factory? He was Tge original owner? Never changed anything??
The forks and axle I sent hotrod were off my 99 EC200. I know that 1 of the spacers were was oem, the other I found in my jar of spare parts, which had misc parts from when I did my front end swap. I am 99.9% sure he has the correct spacers and axle. I don't remeber Mike (Roostafish)ever saying anything to me about swaping out axle or spacers on the bike.
We havent had my sons '99 EC200 out yet. He's getting it from Santa Christmas morning. Hopefully we will be ripping it up Christmas day! Cant wait
this bike quit sunday..he came pushing it back up.. no spark..
we pulled the seat to find where the kill switch tied in and found the cdi ground was broken, put it back on and it fired right up..
you might look at yours, it was an very easy fix.
