Any Kokusan 2K-x (2 stroke ignition) puller will work as well (KTM, YZ, etc.).
The '08 will have a different harness/connector, but the wire colors will be the same. Tnttimber, don't remove your system and ship it with the connector to the CDI, you will need it. There may be some bullet connectors between the CDI and stator, but I'm not sure. You may have to cut and splice five wires, no big deal. Also send the timing insert key that locates the stator in one of the mounting slots. The 2K-2 has no timing key insert. An easy way to time the 2K-2 that I have found is to install an M5 cap screw with an M5 washer into the now unused 2K-3 mounting hole at the approx 2 o'clock position. Rotate the 2K-2 stator plate counterclockwise until the edge (in the cutout portion) contacts the washer, tighten down and your set.
