G GG221 New member May 4, 2019 #1 Computer died all I have is my phone so can?t pull up the manual. I need: Front axle nut Front axle pinch bolts Front brake caliper Rear axle nut Thanks
(F5) Gold Level Site Supporter May 5, 2019 #3 Or just Google the torque settings for a yz250 or anything really will be in the right range.
F fred99999au Member May 5, 2019 #4 I see you are a qualified Engimineer F5. Tighten it till is snaps the back it off half a turn.
F fred99999au Member May 5, 2019 #5 Or use the correct number of elbow clicks varying based on the length of the breaker bar crossmatched with the size of the socket drive.
U Undertow New member May 5, 2019 #6 I don?t know if have these already: Front axle nut 35 Nm Front axle pinch bolts 15 Nm Front brake caliper 25 Nm + Loctite 243 Rear axle nut 100 Nm
