Jakobi just had to go and say he found the JD needles boring so I tried a few others out. I had a needle that seemed very similar in size to the JD red. It's a DEK. Not sure if the taper is different or not or even how to tell. This needle has a longer straight section then The JD red and seemed to have a hellacious hit compared to the N1ef that was in it and the JD red. Anyone else ever try this needle? would the straight section that's longer cause the harder hit? Carb is an AS2 on a 10 300. And both the JD and DEK were in the middle clip for comparison.
