no dipstick on '05fse450
flybars
My '05 fse 450 came without the dipstick connected to the oil fill cap. So far it hasn't been a problem 'cause I always drain and replace with recommended amount and new oil filter. But if I ever lose oil out on the trail, I wouldn't no how much to add. I've called my dealer and they couln't answer the question and never got back to me. Anyone else who has the same year and
model have this same setup? Thanks, Bob
The 2T bikes don't have dipsticks just the sight glass on the side. I always go by known oil quantity. Sight glass is just for double-checks.
I would be surprised if the 4T bikes have a dipstick.
According to your manual, you should have a dipstick.
I'm sure you could order one from a dealer. Frankly I'd really concerned it may be in the frame and potentially clog the fitting/hose into the cranckcase.
Thanks for the heads up eff. Does anyone have an idea how I could locate the dipstick if it has dropped down the frame tube? You know, everyone say's to support your local dealer but if they are not into dirtbikes and especially the brands they sell, I'd much rather give my loyalty to dealer's like Nick and Mark and Steve! These guys ride and know their GG products. Nick has done alot of research on the FSE already, and has helped me find a skidplate and has good advice on dual mapping, rekluse etc. for this bike.
I've called my dealer about this dipstick thing before and they don't know and they don't get back to me. I feel like once my bike left their door's, they forgot who I was.
Sorry for ranting guys, but this dipstick thing worries me and there's little support here. This is why I'm so glad I found this site!!! Actually Oregon Rider mentioned this site when I was browsing another forum. Thankyou very much O.R.!:)
I did not see the frame-style oil fill cap on the 2007. The oil fill cap is on the left side of engine. Was the frame-style oil fill only the 2004/2005 models?
I also noticed the Corporate GasGas site had the workshop manual for the 2004/2005 (no other years available). They did a nice job with the photos and specs. I was impressed. By the way, page 14 shows the dip stick in this manual.
If you don't have the FSE workshop manual, here is the link:
http://www.gasgasmotos.es/web/rcs/enduro/ec_2005/taller_en.zip
I'm sad to hear your dealer problems, but there are always a few bad apples in the bushel.
I have know idea how to locate the old dipstick, and it may not even be in the frame. One idea is to remove the hose at the bottom when you have the oil drained and see if you feel it with the end of a paper clip. Good luck with the search.
BTW just like Matt posted the manuals for many of the bikes are found at the corporate site, www.gasgasmotos.es
Ay Flybars,
Does your dipstick cap have a little round hole on the bottom? If so, then your dipstick has probably fallen down into the frame. Maybe try using a magnet on something flexible to send down the frame or drain the oil and disconnect the frame to engine oil hose located on the lower front part of the frame and see if it falls out of that hole. The dipstick is actually a tightly wound spring 1\16" wide and if you temporaraly want to measure your oil height, it's exactly 9 1\16" long starting from were it comes out of the hole on the cap.
The '05 450 I brought in was the same way, no dipstick! My dist got one too the same way. I don't think the factory installed them.
Thanks for all the help guys. I've got this telescoping shaft with a small but strong magnet on the end. Looks like a antenae. So I thought I'd give it a quick try. I had to arch it a bit to turn into down tube at about a 45 degree angle from the fill hole. It's made out of some cheap brittle metal I found out. So it broke.
I will do an oil change tomorrow and see if I can retrieve it from the bottom.
If that doesn't work I can take a clotheshanger and reattach the magnet. I'll feel better knowing it's not down there restricting oil flow.
And thanks for the manual website. I had tried another one in the past and didn't have much luck. Bob
Perhaps, the dipstick fell off of the cap (prior to install) or as Cladoo mentioned, the factory missed it on a batch. Either way, You won't know for sure until you make your best attempt at retrieving it (if it's there).
Isn't the frame magnetic since it's steel? I would think sending a magnet down inside would only get stuck to the frame tube.
How big is the openning? I have a flexible shaft retriever (not sure of real name) with 4 retracted fingers. When you push on a plunger on one end, the 4 fingers extend out the other end and spread so you can grab an object. I have used it many times for retrieving "lost items".
EDIT:
Did some searching and found the tool from Snap-on's website:
http://buy1.snapon.com/catalog/tools.asp?tool=all&Group_ID=1273&store=snapon-store
There are four choices available.
Here is one example:
4 of the 6 05 FSE450's i sold were missing the dipstick. They were replaced by GG and i never looked to see if it fell off. Never had one fall off and all the bikes have held up well so i wouldnt worry if its in there. The dipstick is actually a section of speedometer cable, with the square end in the oil. I dont even bother to look at mine as i change the oil often and just pour in the correct amount.
I used a long stout wire to probe from the top and couldn't feel anything down there. I then drained the oil and removed the oil hose and couldn't find anything at the bottom either.
I'm satisfied. An oil cap with dipstick is on the way to my house.:cool:
I liked that four fingered snapon tool that Matt R showed me. That will come in handy someday. Also I will be looking for a better magnet with a longer, flexible shaft. Thanks for all the input. Bob :)
http://buy1.snapon.com/catalog/item...&group_ID=1272&store=snapon-store&dir=catalog
This looks like a cool magnet pickup tool. Similar to the claw-style, but the magnet is retracted. Then, with a push of the button, the magnet reaches out and grabs the object. Great idea so it will not to get stuck on mating metal surfaces while trying to grab something. I think this tool will find it's home someday in my garage. :cool:
05 450 fse oil in airbox
3 of my freinds and I bought 05 450's and 3 of us ride them very hard.Does anyone else have the problem of oil in the airbox, comeing from overflow. Even if I'm low on oil it still overflows thru the tube that ends up in the airbox? my compression check is good. I don't think my rings are bad??? Tom
Dip stick 450fse
I have just brought a 06 450fse an that does not have a dip stick like other models it sure is a strange idea an a good way to over fill if engine tends to burn a bit of oil when it gets older.
They take along time for the rings to seat. After awhile it will quit oiling the airbox.
450 fse oil overflow
my 450 has about 3000 miles on it and leaks oil into air box, as allways did, my freinds have about 500 miles and 1500 miles on their 450's and theirs leak the same. I just got a new radiater and my bike is running again. I am going to change my oil and filter and put 3/4 qt. in it and see how much it will leak.
