My rear shock is taking a beating from crossing logs etc.
No one ( that I know off) makes a link guard for the newer GasGas'.
After doing some research, I found the http://www.obielinkguard.com/
They don't make a GasGas specific guard.
So I purchased one for a BETA 250RR.
It mounted up very well.
I had to shorten the rear part of the guard 3/4". I also had to use a longer mounting bolt for the rear skid plate mount.
New mounting hole drilled for rear skid plate mount.
Hole drilled for oil drain. The two mounting bolts fit between the frame with no clearance issues.
Shock not hitting plastic plate.
