Paul,
Always use a six point socket with the face taper releived (ground flat) for maximum contact. If its real bad, try this tip from Les:
Get a six point socket the next size smaller. Grind the outside away at the end as to form a sharp six sided chisel. Tap the chisel socket over the rounded hex with a hammer, until flush with the base. Now use the impact gun. I was able to save a rounded WP base valve this way. Not sure offhand what the size of the Ohlins hex is, I seem to remember it being smaller than the WP. It maybe better to try and use the next smallest standard size socket first, if you can tap it on, before going this more radical route.
