Oil types/best?
W8TSON
Im unsure weather this is the correct place to be posting, please do move if in the wrong section,
Im fairly new to the gas gas as it been my 2nd bike as ive always had small pitbikes :o
Im looking to find out what the best oils are out there to use when its time to service the bike ive been told that silkolene engine oil 10w/40w and silkolene 2 stroke is the very best to be using :confused:
True?
As much help as poss on that matter would be greatful as id like the bike to last and have a healthy enough engine :D
Thanks.
Well, here we have an oil thread! Many opinions, but the truth is most are fine. What works best in the trans, provides minimum clutch drag, and is agreed on by most, is a lighweight synthetic, like Shell Rotella 5W40W, Amsoil 0W10W. For premix all modern synthetics are fine. I use Amsoil Dominator.
First Mr. W8TSON where are you from? (might want to add that to your sig) This can have an impact on what you may or may not be able to obtain oil wise. Helps for suggestions.
And lets not forget ATF for the tranny. Lots of people use it with great success. It's approx. 7.5 weight
Motul 800 is widely regarded as the best oil here in NZ, a nz #1 team mechanic always ran this oil, even in the stickers suggested otherwise, as there oil was'nt good enough. better crank life being one of the main points behind this
i dont know how accessable it is overseas though, never seem to see it mentioned on here
Motul 800 is available here. Its an Ester based racing oil, which is best for film strength. The question I have, knowing that Esters rapidly absorb moisture from the atmosphere, is if it is acceptable to store the bike with this oil coating the parts.
All this oil type is very confusing :eek: Im about to place an order for some silkolene as i cant find any of the above you guys have stated over here in scotland.
bare in mind ive always had a 4stroke bike and still learning as i go :o
Needing:
1, Engine oil - Silkolene - Comp 4 SX 10W-40
2, Two stroke - Silkolene - Comp 2 Pre Mix, Im guessing this is 2stroke mix
3, Coolant - Silkolene - Pro Cool
Hopefully get this all orderd up if someone corrects me on the above :p
Thanks.
Needing:
Thanks.
Get Putoline - widely available in the UK, even Scotland! Try mail order if no luck at local dealer.
http://www.racespec.co.uk/acatalog/Putoline_Oil.html
Cheers Ian i will mail order tomorrow hopefully have it for the weekend and give the bike a full service,
Could you list up what i would all be best of buying?
Thanks
Ok ive made an order,
Putoline Engine Oil - MX7 1L
Putoline Gearbox Oil - GP80 MEDIUM GEAR OIL 1L (SAE80w)
Putoline Coolant
NGK Spark Plug - BR8EIX
Hopefully ive got the above correct :o
Hi! I'm new on this forum and a newbie in mx & enduro. I started all these things the spring & 17 yr old. So far I've loved it.
So my question is that how much do you put gear / clutch oil to 2003 250 ec.
Manuals I found from inthernet says that the transmission oil capacity is 1800cc. Can it be that much?
I putted 800cc and i can see the surface from the "window" on the right side of the engine.
And what oils do you use in these bikes??
I putted in Valvoline durablend 10-40 and it feels pretty good. Are these oils ok?
900cc of Shell Rotella T Synthetic 5W-40
Putoline Coolant
Almost. You'd have been better off with Putoline Light Gear Oil.
I changed oils to my Gasser today, and the old oil was totally black and smelt like exhaust gas. What can cause this? Can there be a leak somewhere?:confused:
The old oil was propably 3 weeks old, or 4-5 hours.
Just bought...
Hi, Im in Sunny South Wales...Haway the Celts !!.. my 05 300ec gear oil is 900ml. I just got some Castrol 0w30 synthetic...not sure how this is going to go, havent put it in yet...
but I would imagine that your capacity would be the same as mine at least...
so try 900ml....I got the info from the Gasgas manual...
Hop this helps...
