Yesterday I noticed my GasGas badly overheating while climbing a hill. On the hill it just ran out of power, pinged bad and would not shut off with the kill switch. Prior to that it had some signs of minor overheating – erratic high idle and feeling a bit hot, but otherwise normal.
I checked the cooling system and it was not pressurized so I opened the radiator cap. I could not see any fluid or steam, so I proceeded to add a bit of water. When the water got down to the engine I had a massive percolating boiler spewing steam out the radiator cap. Eventually things settled down and I put in about a quart of water.
At that point I was wondering where the coolant went since I had not had any boiling out. I looked in the sight glass and saw a gray milky liquid. I tipped the motorcycle on its side and I could still see liquid in the sight glass so I assumed the coolant went into the transmission.
I rode easy back to the truck. The motorcycle ran fine with water in it for about 8 miles back to the truck.
At home I drained the transmission. I end up draining 2 quarts of grayish milky fluid out of the transmission. That accounts for where the 1 quart of coolant went – into the transmission to mix with the 1 quart of transmission oil.
I assume the water pump seal failed.
My plan is to…
1) check compression (if good leave the top end as is, if bad rebuild)
2) replace the water pump seal and check for any other potential leaks
3) change the transmission oil and ride it briefly, continue with oil changes until the oil comes out clean.
4) flush out the cooling system and put in new coolant.
Anything else I should look at?
My plan is to…
