Pampera 400 '06 Ignition Coil replace
Il verze
Hello to everything. While I was working on my gas pampera 400 gas, I was closing the flywheel crankcase and I accidentally broke the ignition coil.
I can't find the original spare part.
Does anyone know if I can adapt The Ignition Coil from another similar bike?
Generally people call the frame mounted ht coil the ignition coil. The stator contains the ignition charge coil. But I suspect that you are talking about the small plastic case which in English has several names. Pick up coil. Sender coil. Pulsar coil, and probably others. Then of course the Spanish ones.
Fortunately all they do is pick up a small charge as the flywheel goes past that tells the ignition to fire.
The good news is that it should be easy enough to find a similar coil. If like the Enduro 2 strokes the run kokoshin electrics, ktm use them.
Probably not as a single part, but a burnt out stator loom would have one.
Found these separately but you'd have to confirm size and mounting position.
https://www.ducati-kaemna.com/catalog/ducati-classics/ignition-ducati-classic/pick-up-250-ohm-1467.html?___store=tuning_en&___from_store=tuning_en
Hi everyone, I took the bike to my trusted mechanic and he managed to solve the problem. Thanks everyone for the advice.
