Parting out '04 EC 200
gtsnowcrack
Crank stuffer bolt in cylinder results in sale of parts:
Updated with prices, everything is subject to negotiation and is without shipping.
  • LTR Case Saver - $20
  • 1 NoToil Air Filters -$5
  • New NoToil Filter - $10
  • FMF Gnarly & Fatty Pipe - Mangled-Cheap - best use would be a boat anchor, they can be worked on and they are functional but far from pretty. $20 each
  • Rear brake Assembly - $30 (no lever)
  • Moose foot pegs stainless - slightly bent -$30
  • Computer - No sensor -$40
  • CDI - No idea, make an offer
  • Bottom End - Little to no damage from bolt incident, cases should probably be split and the rod replaced - $200
  • Swingarm Bolt $10
  • Linkage assy - $20
  • Stock tank with cap and petcock - $75
  • LTR Needle - $10
  • FMF Turbine Core SA
  • Marzocchi Soft Fork Springs .38 -$40
  • Ohlins Soft Rear Spring 4.8 - $40
  • Front wheel DID U-style rims - has a crack at the weld, easy to zip up, will take pictures - $75 Pending
  • LTR PowerValve Cover-Pending
  • etc
SOLD
  • Reed block with functional stock reeds
  • Used plastic, all yellow
  • New Front Fender - yellow
  • New Rear Fender - yellow
  • G2 Throttle cam (Fits some years of KTM's as well, check)-Sold
  • Rear Wheel-Sold
  • Air Box Boot - Sold
  • Air Box - Sold
  • Carb - Sold
  • Rear Brake Pedal-Sold
  • Seat - Foam and cover torn, useable, good base-Sold
  • One set of plastics with stock graphics -Sold
  • Cylinder Head - Killer bolt did not get to it - Sold
  • Clarke Oversized Tank with cap and petcock -Sold
  • Radiators - Sold
  • Eline Carbon Fiber rear disc guard - Sold
  • Rear Axle -$10 each
I'm building up an off road '05 YZ125, if you have any parts that fit it I'm up for trades.
gtsnowcrack at gmail dot com
How much for:
-Stock tank
-would you sell the shrouds separately from the rest of the plastic?
-LTR powervalve cover
-LTR jet kit
-FMF Turbinecore SA
Thanks.
Im interested in prices for:
G2 throtlle cam. How many cams 100,200,400?
New front fender
New rear fender
Let me know. Thanks!
200 parts
I would like the clarke tank and the stock shock spring. I am in phx so if you could give me a call we could do bizz this weekend . mark 602/565-4402
I would also be interested in the wheel's !
"KicksonR66" I will take seat if JoshP doesn't, not sure if it will fit '02.
I just picked up a gripper seat so I will not be grabbing that.
Thanks Josh, I definetly will take the Seat base gtsnowcrack, if you need to sell cover and foam with it thats ok too. I will be out of town until the 10th so I will get with you then if thats ok. I'm still not sure if will fit an '02, can anyone verify? Thanks
John
972-768-1370
jt.blackstone@sbcglobal.net
