parts crossover on nissin calipers
gassergrant
hello is my ec 300 (03)share the same front caliper as the cr500(94) as im after some new pistons for my one. i bet gg ones would be cheaper, there both nissin and look the same ? just piston dimensions
thanks grant
thanks grant
Should be the same as a '94-'98 KX250. I keep a '95 around as a parts bastard.
Are you guys saying the CALIPER itself from those Jap bikes is compatable, or does the whole mount just bolt to the GG fork?
I'm having the same problem on my '06 EC 300, so I'm wondering how easy it is to swap the caliper from one mount to another?
It is easy to remove calipers from the bracket, but I cannot for sure promise that they are identical on mounting. I know that the brake pads are very common between Japanese bikes, so one could assume that the mounting points would match up from the caliper to the bracket.
