I bought a used 2011 300ec with an estimated 70 hrs on it. I took the pipe off and examined the piston and cylinder walls with a led flashlight. Cylinder still has cross hatch marks and piston shows no signs of scoring below rings. I did manage to put my finger in the exhaust port and found play in the piston from side to side. My question is, should I put a new piston and rings or just rings and a new piston after that set of rings? Top end is original. Thanks
