I finished making up my damper mounting parts and went to install my bars. First thing I notice is that the brake hydraulic line exits out on the rear side of the master cylinder. When I go to angle down my levers, the hose strikes the bars too early. Forget about having room for a handguard clamp.
The clutch is better as the hose is closer to the centerline of the master cylinder. It does hit my handguard clamp bracket. Should be OK with the bracket removed. I see now why guards that attach to the top crown are popular.
I guess some riders pivot their bars forward to help angle their levers. I angle my levers down about 20 to 30 degress from horizontal. I have seen some guys put theirs on a 45* angle; I suppose this helps if they stand all the time while riding.
I can make up new brackets to get around the handguard problem, but the brake hose is still an issue. Has anyone bent the fitting tube to gain more clearance? Or ground off the locating posts to swivel the fitting more?
