2K2? Wires exit at 11 o'clock.What ignition does it have?
Would that 2k-2 fit 2011 ec250?
Seat cover is original with yellow stripes and GG on the side. Seat foam is excellent. Cover has no tears but has worn through or came loose at the very back. Repair would be simply sewing a narrow strip across the end of the cover. I also have a latter (03,04, or 05) seat that is original with wide yellow and white stripes on the side with GAS GAS in big letters. It is perfect except the JT Throttle patch on rear is starting to cme loose.Just wondering if the seat is in decent shape and what seat cover is on the bike.Maybe you could send a pic? Also I'd be interested in a skid plate if you have one. Thanks.
$495 plus shippingi might be interested in whats left after pat:
Primarily frame,engine,swingarm, rear shock, fuel tank
Chris give me a call. I haven't talked to you in years. I would have called you already had you left your # when you left a message on my home phone. I won't part this fine bike out unless I get some real interest in both the front forks and the motor. Wheels are DDD U, pipe has no dents, bends, or kinks to the header section and only 3-4 1-2 inch dents that are 1/2 inch deep or less in the next section. No radiator guards.Ken what condition is the pipe in and do you have any radiator guards.
Do you have the front wheel and is it the DID U
