andrewjtheis
So I have combed the threads, and I found a few similar, but wanted to post my own with my own issue. here are the details:
2010 250 EC
185 PSI Compression
Brand new Pack on FMF Turbine Core
Fresh clean air filter
Kehein Carb
Fuel: 50:1 Motul 800 oil
Decent size dent in pipe (i think this has NOTHING to do with this)
Jetting:I can't remember the jet #'s but all of them are leaner than stock.
Spark Plug; NGK BR8EG, color looks slightly wet, but not horrible.
My problem is: i have absolutely ZERO mid range power. after 1/4 throttle its bogging VERY heavily til i get up into 3/4-full throttle, I moved the needle down one notch (it was all the way up) and even then its weak at best. I am also getting a TON of spooge (black) out the tail pipe already with the silencer freshly re packed. COnventional wisdom says its rich, but the plug tells differently and the bike is already jetted lean. I have heard crank seal, but i have no experience with this. any help is greatly appreciated. thanks guys!
2010 250 EC
185 PSI Compression
Kehein Carb
