Hello i have a 2002 ec300 and im running putoline mx9 at 50-1 but my power valve is dripping oil out the tube is this to much oil or is this a good mix for the mx9?
They will sponge more if you are jetted rich, but if they are not ridden hard they will sponge even when jetted correctly especially with high flash point oils.
I've Always run 40:1 so 50 is not too much. Jetting will reduce spooge and it's the needle that will make your change. But who cares if there's s bit of drip? It's what it's for. Actually I cable tie mine up and drain it ever so often.
