Hi I have a ec300 2008 when I look behind the power valve covers on the barrel there seams to be a lot of oil, I’ve read somewhere that it can be crank oil seals , is this the case and how easy are they to change
(being a 2008 i would be surprised if this is still the case but)
from the factory the breather pipe from the powervalve side cover is crimped closed which can result in oil buildup in the PV, most people allow this to breathe, but yes it will be nicely tarred in oil
If you jet it perfectly there will probably be that much oil. But the bike will run crazy much better..
Look at the jetting threads.
Enjoy. Fantastic bike.
