Pro carbon racing pipe guard
nambo-trev
Hey guys just wanted to see if anyone has tried any of these guys products? I bought it from the uk and had it shipped and still saved around 50 bucks over the p3. I've put a p3 on before and fit is close to that, just wondering how there products hold up(not that it matters now!) here's a few picsImageUploadedByTapatalk1353987866.472548.jpgImageUploadedByTapatalk1353987879.584278.jpgImageUploadedByTapatalk1353987892.884429.jpg
Yes there made in the uk and it seems really well built, I don't see any advantages on my buddies p3 that would make it any Better but time will tell this winter how it holds up
I have a ProCarbon pipe guard on my 2010 250EC and so far it seems to have done its job pretty well. I have over 100 hours on mine riding in a variety of terrain (and falling over a fair bit!). There are a few cracks starting to appear on the bottom edge where it takes most abuse and the usual scuff marks. My mate has a P3 guard on his 300 and it would be a tighter fit to the pipe than the ProCarbon version, which isn't necessarily a good thing as the gap allows the ProCarbon one to 'give' a little bit in a hit. His P3 also looks a bit 'burnt' and is starting to craze quite badly from heat I would presume. The P3 probably covers a bit more of the expansion chamber but not much. You do need to clean it out fairly regularly as it does trap quite a lot of dirt and can lead to the pipe developing surface rust (but also hides it). All in all it does what it says on the tin and like you say it's a good bit cheaper than the P3.
I had an E-Line break after the first hard hit from a rock, and have seen a bunch of others of various brands that are cracked and broken. I don't think carbon fibre is strong enough of a material. I went back to aluminum. Cheaper and better I think.
Thanks.
I'm also tired of fixing dents in my pipes:rolleyes:
Can't find any GG specific guard on the link, is it just a one guard fit all? the one under "other makes"?
There is a specific one for gas gas as iv seen it somewhere , maybee ebay but cant remember:rolleyes:
I made one from a piece of expanded steel once. It worked great, but is sure was ugly! Only cost 20.00 and an hours labor.
Hopefully it will hold up, I'm hard on pipes so ill find out quick, I've tried metal and plastic Hyde guards and all had there flaws and positives, I've yet to see any of my buddies carbon guards crack or break so I'm hoping I have the same experience. I'm sure a lot depends on ones riding style and level of riding as well!
CF guards break down from repeated small hits (the resin). To the eye it looks fine but the cloth can actually flex. I've pulled them off to find a dented pipe. Also, they stiffen the pipe when clamped on, so the header kinks in a hit, and is very difficult to fix. The only real sound way to implement a pipe guard is to integrate it to the skid plate or mount it to the frame. For whats available now, that means Hyde Combo. The R&R totally sucks on the older bikes but a Combo for an '11 fits great on a '12 and the holes even line up perfect with the factory frame mounts! I made a custom rear mount that captures between the linkage pivot and frame tube and I can have it off in seconds for cleaning or an oil change, so easy I didn't even bother adding a hole. Foam keeps the mud under control. I think that when you hit something, it both flexes a little and slides off rather than bites in, so less impact energy is transfered. I still have the original pipe on my '07, riding in serious rocks. I have never been able to say that with carbon fiber guards. Given the choice I'd just buy a $40 Moose bend it yourself alloy guard over a CF guard.
I have been very satisfied with my P3 CF gaurd which I bought used, so it saw some action before I got it. I have slammed stuff, crashed into stuff layed my bike over on stuff and the gaurd has done it's job great, without it my pipe would have been destroyed several times by now. It has some sign's of wear but is still holding up awesome, I would get another if or when this one fails but I will probably have a new bike with a different pipe on it by that time anyways. As with anything else, everything will have it's pro's and con's.
I've had the Hyde combo plate and did not work well for me. It broke down and the rivets started to come loose and twist up on me even with tightening after every few rides, it was almost useless on the front pipe when I finally took it off. It also constantly filled up with a pile of crap after every ride. From my experience I would never buy a Hyde combo again. The carbon seems to be working well for my riding buddies so l guess will see
The one on my '07 is beat to hell too but still intact, no rivits loose. The thing with the Hyde is the mounts suck, you have to fab your own and it works a lot better.
There is also an alloy combo from Force in Austraila but its too expensive even before shipping.
I think anytime you integrate the pipe guard with a skid plate you will have a mud trapping issue, except perhaps on those custom tubular guards you see in Hawaii. Thats why I use the foam.
This is a tough nut, protecting that fat pipe. You find something better I'm all ears.
