d2w
Folks,
In an effort to "force myself to stand", I want to raise my bars. I was going to experiment and make some simple aluminum spacers (1/2", 1", 3/2") and place them between the upper triple clamp and the lower bar mounts. Obvioulsy, longer bolts will be required.
But a problem I foresee is making my Scott damper work. I'm currently using a Fastway upper bar clamp with an integrated mount for my Scotts damper. And the Scotts tower is mounted to the frame at the steering head.
If I raise the bars and damper within my range, I don't have enough length in my tower rod to go the extra length. My Scotts arm does have a jog/kink in it to lower it slightly, and I have the "long" 65mm tower post, but there's no way I can make it work if I were to go the full 3/2" up.
Could I have machined a longer tower rod? Or will the damper not work well with that much length between it and the tower mount point (i.e., too much flex)?
I guess I could experiment with my current bar and risers and no damper, and then find a tall bar once I found a setup that I like (and keep the damper low).
Your thought on the matter are appreciated.
Thanks.
Dale
Thanks.
Dale
