fullthrottle
under the lh side pv cover the shaft with the thread has about 5 mm of in/out movement it has been like this since the first time i looked under there (when bike about 2 mths old). What i am wondering is i can hear a slight knock eco through the cylinder and it sounds like the noise you get when you pull that shaft fast in or out and take up the play. the bearing itself seems to have quite abit of movement in the housing before it hits the retaining washer. the noise sounds abit like the chain slider it happens when you just get back on the throttle slightly at medium rpm, but it still does it when the bike is stationary and out of gear and i give it a few small blips of the throttle and ideas?? i have been riding it like this since new but it is annoying me and when i speek to othe gasgas owners (notmany around here) they say they dont have the same problem. mabye someone here can help me ???
thanks
thanks
