PV question/opinion
after reading about the power valve stop adjustment, I took a look at the one on my bike.
bike shut off the triangle piece rested against the bolt
bike running the triangle piece floated about 1mm away from the stop bolt
does this sound acceptable or should I tear into it and adjust it?
in the picture on the left side of the power valve under the cover there is no stud, I've seen some with a stud and some with a threaded stud. mine having no stud could it be installed incorrectly?
I had removed the blot the washer on the left side
