EC300 with new S3 cylinder and head. Black high compression insert, squish is as tight as I can get it without machining at 1.25 mm. The black insert is the only one that gets squish even in the ballpark with a thin base gasket. Kicking compression reads 165-170 PSI.
Have not run the motor yet, I am wondering if this set up will require race gas or a mix of pump and race? Previously I have run 93 octane pump on the stock EC with an RB head. Opinions? Thanks.
