wence
Bronze Level Site Supporter
Well, went out to the Supermotard day all keen to give the bike a blast and got three warm up laps done before we were diverted back into the pits ready for the sessions to start.
I decided to bump up compression as the bike was diving quite badly in the tight stuff and at the end of the straights.
After doing so I noticed a fluid on the ground near the bike and thought it was fuel.
After closer inspection I realised I had a leak from the radiator.
I changed the clip up radiator clamp for a proper clamp and then noticed it still leaking.
Decided not to rdie as by the time I got it apart and fixed and then back together the ride day would nearly be over.
Got it apart today and noticed that the bottom tank on the right side has not beenpressed up properly.
The tank has obviously hung in there till now but has given up the ghost due to vibration ( I assume).
Bit of a pain and now off to the radiator shop to see what can be done.
Not sure whether to push for a warranty job as the guards have actually rubbed one of the tabs on the radiator tank and although that is not the cause it will no doubt be an out for the warranty( maybe?)
Cheers Mark
Cheers Mark
