Radiator Fitment
GLantern
Was there any change in the radiators from 2011 to 2012? Just seeing if I can use older radiators on my bike. Thanks for the info.
As far as I know, yes they did change. When I got my 2012 the previous owner had used 11' radiator Scorpion Guards, and the guards were modified to fit the '12. The main difference is that the '12 are wider then the '11.
Use the search tool on this website and you should find out more info.
Thanks Stu looks like I'll have to make sure I get a 12 radiator then. I had searched but I didn't find anything on the Fitment.
How about the Ktm rads? Do we know which ones fit the 12s?
And had anyone else had rad problems? Mine failed on the right side at the bottom hose joint. I didn't think it would be so weak.
