rear axle Q
nokturnal
are there any rear axles that will fit my 06 EC250 that DO NOT have the "pin"?
I would like to have some spacers made up so I can use my STS stand, but I require an axle i can put a pin through from one side to the other.
TIA
no?
ok how about this... does anyone have a rear axle on there bike that does not have that little locating pin to keep it from turning when tightened?
no?
On a '01 EC250, I used a rear axle from a '95 KX250(no pin). Hold the non-drive side w/adjustable wrench, and tighten away.
TIA
Sorry, didn't answer this Q. Yes, the kx axle is hollow all the way through.
cool thanks. 1993-2002 KX 125 and 250 use the same axle.
does anyone know if the 01 and 06 EC have the same rear axle specs?
