Rear brake calliper crossover?
Rear caliper cross over
Hey, I was having rear caliper issues on my 05 300 and rather than buy a new caliper I went ahead and rebuilt the old one. I used a 97 Honda CR250R rear caliper seal kit and it fit perfect. Just make sure you clean the piston and inside the caliper really well. The little gaps where the seals fit in need to be free of any dirt and debris. Brakes work better but I still think brake pedal slop is the source of the majority of my rear brake weakness. good luck! But a honda CR250 rear caliper is exactly the same part if you decide to replace, But the rebuild is very easy and should only take you about 10 minutes.
