Rear hub bearing washer
kendunn
I screwed up my rear hub bearing washer (the washer that goes between the two bearings) and I was wondering if there was something else that would work in there or if it was a standard item or something. I don't have a local dealer and hate to order small parts as I know the dealer hates to bother with it. Ideas what will work? Also what are the standard seal numbers for the rear? Thanks
Kenny
Just removed my rear bearings & have found the previous owner had destroyed the washer!!! Have ordered a genuine replacement from my local dealer. I'd say that might be the route to go down, however, I'd think that a washer/shim of the correct thickness should do the job just as well.
