Hello.
Sorry for this. Ive read bits but just want to check ive understood this correctly
Bike is 2006 ec 250 with ohlins shock
Ive got 105mm of rider sag but this gives a whopping 55mm of static sag.
From what I thnk this means I need a softer spring. Im not sure how much by but think next step is to remove shock and then spring to try and see what spring is currently on it?
Is the shock just a case of undoing bolts at top bottom and out it comes? The linkage appears to be blocking the bottom bolts so have to undo that as well
Thanks
si
Thanks
si
